Bad day at the office
So the sun's shining, no plans all day. Think i'll fit the new mono leafs on the rear. Adam reckoned an hour each side, i reckoned on three.
Two and a half hours later and i've got one side off.
Damage so far, 3 out 4 front spring hanger nuts sheared on removal, not sure how to get remnants out yet.
Took 1 hour to remove two of 4 spring hanger nuts, having to constantly cool tools and nuts, wind up and down threads until loose.
Rear spring hanger, both nuts sheared off
Rear spring hanger bracket, 1 of 2 nuts sheared off. No idea on how to remove sheared remnants as yet.
Only good news. I had a spare spring hanger from Dunc sat in the box for 3 years, at least i'll need it now.
Sod it, i'm going down the beach :twisted:
No fun is it? :roll: I Always cut the U bolt threads back 3 or 4 threads from the nut before attempting removal. :thumbright:
Latil,thats the least of it. Currently, i cannot drive out the old spring hanger from the brackets. At trhis ratei'm going to have to have some brackets made up. Crazy :roll:
Undoing is anti-clockwise, Fella! :shock:
Not undoing Kev, I need to drive the old rear spring hanger out of its bracket. Its welded itself to the bushes. I reckon a
i'll chuck it into the barby tonight and burn the bugger out!
Meantime, small victory as i managed to get the front eye bolt out without drama.
Just wondered about your undoing technique :D Clockwise tighten, AntiClockwise untighten! :thumbright:
Gareth
Post by Gareth »
Lefty loosey, righty tighty :D
Unless it's the Suregrip or one side of the car's wheel nuts! ;) (Or the screw that holds the chuck onto your battery drill!)
Come on fellas, you know these can be a PITA if not touched for donkeys :roll:
Those bolts will knock out the front hanger , same as wheel studs , no probs . :thumbright:
:thumbright: 8-)
i undid 'em, they snapped! Just the way it goes . As Adam sez, this car has not been maintained by a car loving purist for the past three decades. To be fair, out of all of the jobs i've done, this has been the the biggest PITA.Well, since the last one :?
Hang in there Miles , still loads more PITA jobs to look forward too.
Until you remove the last nut/bolt/screw of your own car and replace them with correct torque/fastener/glue there will always be PITA bits!
thats for sure Kev, I undid the other side today and the rear hanger and brackets all came of sweetly, cos I replaced them 3 years back.
Even better, no shearings on the front brackets today.
Can't wait to get the job finished. I gave the car a near full throttle start the other day, hooning around. Car moved about 3 yards and just fried the hides, smoke everywhere. Hope the mono leafs will help a bit with the lack of traction.
