brake proportion valve
ok ive ordered me new wilwood disc coversion and its on its way i also orded the proportion valve thing, were and how do i fit and set this up????? :oops:
Splice it into the line that heads for the rear brakes.
ahh cheers dave , so all it does is restrict the flow to the rear
Correct.
i assume you bought an adjustable one? Fit it to the inside of the chassis leg so that the knob points down. That way you can test it and adjust it at the roadside by reaching under. Saves getting dirty knees on your clean strides. :)
lol kk i was having a look earlyer and thinking of putting it there, yea i got an adjustable wilwood one
MrNorm
Post by MrNorm »
Or put a hole in your floor and you can adjust it from the drivers seat. I even used an existing hole to do this (see my buildup pics)
umm cheers gav will keep in mind
