Watch your fingers on the shims though. They are like razor blades.
These are my rockers.
Designed specifically for better geometry on the 440.
Held on with studs instead of bolts.
Very heavy billet steel shaft hold-downs and separators. Centered on the valve tips and adjusted for tight oil clearance using shims.
Mounted on banana grooved shafts for better oiling.
Make sure you put your rocker shafts on the right way around mind. They only go on one way you know?
