On the gayvan again
At low revs the steering is heavy, feels like a manual box, but is fine at speed.
Fluid level is fine, and belt is nice and tight.
What gives?
Power Steering Q
Efficiency of PS pump is relative to rotations on pulley wheel versus crank speed.
Do we assume this issue has always been there, or is it a new problem????
Assuming it is the right pump for the van you MIGHT find you need the pump to turn quicker at low revs so you need either a bigger crank pulley or a smaller PS pump pulley.
The main thing is, is this a new problem???
