Yoke won't fit on Pinion splines
Anyone any experience of Ford 9" diffs?
I've picked up a used (ex-Nascar) ring & pinion and a forged yoke. The yoke starts to go on but jams 1/4" in. If i 'assist' it with a big hammer it'll go on 1/2" but it gets a lot tighter.
There's visible wear on the splines on the bit i can get the yoke on.
My 1st thought was that the splines had distorted but now i'm wondering if they're actually different sizes and they only start cos they're worn :?
Would they make 'em so close but not the same?
Bought from ebay U.S. so no returns or help there.
Totally stumped here
HELP :cry:
No real knowledge of any Ford axles, but a quick glance here,
http://www.ringpinion.com/PartsList.asp ... fferential
Seems to suggest they come in 28 or 35 spline and that's it....
I reckon any of the UK chassis builders could tell you for sure.
Cheers Blue, heres a couple o pics of the offending items...
I'm sure this is answered on here already somewhere but it's late and my heads battered now...
How do i tell what yoke i have? i.e. 1350/ 1330 etc?
Run it , if it breaks there not the 1350s.
Only messin. :D
Well it's ex-Nascar so i think that answers my question :thumbright:
SORTED :D
Spent a week with a very fine file & fine sandpaper reprofiling the pinion teeth. I marked all the teeth with a marker pen then slid the yoke on & off in all 28 positions. Wherever the pen was worn off i skimmed a bit off with the file, smoothed it with sandpaper and repeated the process. About a hundred times :shock: felt like that anyway ;)
Now it slides on lovely and smooth with no play :thumbright:
I've shimmed me pinion and bolted it to the main housing, welded up a stand and fitted the ring gear assembly so now it's adjustment time.
db wrote:SORTED :D
:shock: :shock:
Now that's dedication.
It's amazing what you'll do to avoid spending money eh!
