When I start the car, the brake pedal does not move or work the brakes. This indicates a servo problem I believe. The pipe to the engine looks ok, but connot fathom the conection to the servo. Should it just pull out?
After a couple of minutes everything works perfectly. Anyone know what the problem is please?
Tony ('69 GTX)
Servo problem - B Body
- latil
The vac hose may be collapsing internally,or there could be a crack that closes as it gets warm. The non return valve on the servo may be sticking.The connection into the servo is the non return valve and is pushed into a rubber grommet,it should come out with a twist and pull.
