Line Lock woes !
Line Lock woes !
jus fitted a hurst line lock, but it dont hold ! ive jacked up the car and cant move the wheels with the brakes applied and the same with the line lock on ? but when i try to put the pedal down it creeps forward ? the brakes are new last year, their peugot 807 discs etc , any ideas
My linelock doesn't hold unless I apply it twice. Brake, switch linelock on, release the brake pedal then brake again and release linelock then switch it on again. I'm not the only one who has to do this either so I don't worry about it. Pretty sure it's its a Hurst linelock too just badged as Summit.
Think this has a lot to do with discs or shoes , i take it Mick has the line lock solinoid holding the fronts being a 4 speed , bearing in mind calipers have a much larger displacement area than a cylinder , i have the line lock operating the rears with no issues , maybe if the fronts were drum brakes all would be good with one stab @ the peddle.
