Charging system
Charging system
Dave,The Ammeter shows +20(0 when I was coming back from Brooklands,What would happen if I have put the Wires the wrong way round?(I have had the Dash out to repair the Clock) :oops:
No idea! :)
Guy
Post by Guy »
It should show a negative charge.
make sure that the teminals are not shorting on the back of the dash i had major problems with this a couple of years ago. Also check that the fuseable link has not burnt out (wire casing gone all crusty)
SUCCESS!!!!!!!!!!!! :toothy4: For once the Plymouth P.O.S has played the game,wired the alt straight to the Batt.........Loadsa charge!!!!!!!!!!....going up to Duncans Weds morning,up the M40 etc, anyone about give us a toot,will be in the inside lane cause the 727s lost 2nd.Thanks for all the info.
Alex
Post by Alex »
Be carefull how much charge you are making if you wired it direct, the reg should still be working if you left the field wires on on, but be sure...
