hand brake bits missing
hi everyone took rear drums off today to see why the hand brake cables werent hooked up and found there were some bits missing just dont know what
and does anyone have any i can buy off them
- Charger rear brake 2.jpg (37.6 KiB) Viewed 225 times
- Charger rear brake.jpg (35.9 KiB) Viewed 225 times
Here's some pictures of my rear brake set-up - note the thin spring at the bottom, mostly hidden by the half shaft flange, and the other thin spring which houses the park brake cable, attached to a park brake lever normally found behind the trailing shoe.
Hopefully the images will give you an idea of what is missing from yours.
Hope this helps!
Hope this helps!
- 097.JPG (165.91 KiB) Viewed 197 times
- 096.JPG (171.11 KiB) Viewed 197 times
- 095.JPG (156.56 KiB) Viewed 197 times
- 094.JPG (171.51 KiB) Viewed 197 times
1973 Dodge Challenger
MMA 616
MMA 616
