727 CONVERTING TO KICK DOWN CABLE ....help !!
hi does any one have any pics of how to set up a universal kickdown cable for 727 torque flight onto a 750 holley ???
also wen its connected up how does the actual kick down work???
does the cable have to be tensioned so the linkage on box is being pulled and does this rely on throttle spring to pull it back as mine seems throttle is slighty open ?? i basically need to know how to set up cables correctly etc??????????
im in the same boat paddy ;)
Gareth
Post by Gareth »
The Lokar cables come with a nice clear instruction sheet. Not sure what you guys are using but I'm sure the same instructions would get you there or thereabouts.
http://static.summitracing.com/global/i ... 518htc.pdf
Is this a Lokar or similar?............the cable kit should come with some brackets of sorts , the cable is mounted to the front section of tailshaft housing which then pulls rearwards on kickdown lever , the other end connects to the bottom portion of throttle lever , adjustment is carried out on the bracket that holds the cable to manifold/carb bolts.
Here is what I did :)
DSC01351 lokar set up.jpg (134.05 KiB) Viewed 769 times
Gareth
Post by Gareth »
Now you're just showing off with those posh ally brackets, aren't you, Drew.
What's wrong with a bit of plate bashed to shape with a hammer ?
:D
Gareth wrote:Now you're just showing off with those posh ally brackets, aren't you, Drew.
:D
:laughing3: :laughing3: :laughing3:
I should dig up my old unit I made, but it fell apart :D
Here is the part
http://www.summitracing.com/parts/CSI-631C/?rtype=10
hey cheers for help, its not a lokar cable cant remember name of it but bouhgt it at mopar nats from one of the stalls it does look like a strong kit not a cheap one !! so ive got it all connected up but with the tension on the kickdown to hold it back the throttlr is not returning shut its slightly open ???
is the top linkage arm on box the kick down as thats the way it seems to fit and work?
any one any pics on the gear box, mine is connecting to holley 750
AllKiller
Post by AllKiller »
Pictures ?
You got more than one return spring, right ?
ALL KILLER NO FILLER
Yes the upper lever is for the kickdown. You need to use a light spring to hold the lever forward so the cable has a little pressure to pull against. It also helps if you cable tie the cable to something at the point where it loops forward at the rear of the box. If you don't do that the whole cable moves and you lose a lot of it's travel.
Scooby
Post by Scooby »
Drew....class mate :thumbright:
Rich....
072
yep all sorted now she should be running in next couple of weeks after complete build so il know when i drive her if it all working correctly, thanks for the help guys :)
