Pitman Arm torque setting?
As the title suggests, does anyone have info on what to tighten the Pitman Arm nut to?
It could be 130 lb/ft but it's not clear in the manual :scratch:
Also, what size socket is needed? Looks to be 33mm or 1-5/16" ?
Thanks :thumbright:
Sounds about right Twins!
A two foot long breaker bar will give you about that sort of torque if you don't have a Talk-wrench.
baccy
Guy
Post by Guy »
baccaruda wrote:A two foot long breaker bar will give you about that sort of torque if you don't have a Talk-wrench.
baccy
Well that depends on who is pullin on the bar ;)
Thanks chaps. A bit more digging on t'net and it looks like it should be 175 lb/ft :shock:
So that's prob a 3' breaker bar :read2:
