Gauges Reading Full/Max
Hi Guys (and Girls)
Had a great time at Brooklands on Sunday.
But driving home, my fuel and temp guage went right off the scale - max - and stayed there. Is there a simple way to check whats causing this, am I right in assuming it might simply be a dodgy earth or something.
Where would the first place to check be?
Thanks
Martin
It is unlikely that both "feeds" are earthing - try disconnecting them from the sensors and see if the gauges drop to zero.
Are all the other gauges playing up as well?
It could be the Ballast resistor under the dasboard.
Alex
Post by Alex »
Sounds like the volt reg has stuck as Pete says, if it has you need to solve the problem fast as the guages will not be able to handle the voltage.
If the oil guage was still reading right that is almost definalty the problem.
Hi
it doesn't have the oil gauge as such, just a warning light - which is off.
Anyone know where I can get a ballast resistor quickly, as this is now my daily car :(
Thanks
Martin
I've ordered a new one from WASP - should have it by the weekend. :)
If you asked for a ballast resistor you will get the one for the ignition. :!:
oops :?:
what should I ask for?
ask for a voltage regulator for the clocks/dashboard
Hi
when I get the voltage regulator, are there any tips for fitting it? You know, something obvious, that I might forget to do.
Also, do I need to take the dash out?
Cheers
Martin
Guy
Post by Guy »
Disconnect Battery :)
Ok guys, here's the latest....
Fitted the ballast resistor, voltage reg (but even though I asked for a dash one it seems like an ignition one was sent). So I guess I still need one...
Anyway here's piccies of what I have fitted, and piccies of what the gauges look like with ign on.
Now, when I was driving home from Brookie the fuel and temp were well past the max, but now only the fuel gauge does this.
Any advice appreciated...
now, is this the part I actually need?
Yes that's the fella! I think you can get a transisterized version now which is much more reliable, Year One do them I think.
Holly
Post by Holly »
Yeah, the silver one ... hope your fuel guage hasn't got roasted!
