Having difficulty removing ball joint from UCA. Anton has lent me the correct
socket however even using a long breaker bar it will not shift. not wanting ti damage tool or UCA anyone got any tips for removal.
cheers Jerry
upper ball joint removal
heat the threaded ring of the control arm with torch a little !! don't have to go mad & get it red or anything !! then give it some with a breaker bar , wear gloves also ,
thats how i done mine , should of left it on the car to do it though as ended up moving the steel 3 meter work bench that was bolted to the floor !! with control arm in vice all round the garage while trying to undo it with a breaker bar !! two seconds of heating with a torch !! easy
- mopar_mark
- Adrian Worman
- mopar_mark
I know Jerry tried that same method, ended up snapping his breaker barAdrian Worman wrote:A breaker bar and a for foot length of galv steel tube on the end was my preferred method, still a bit worried about putting that much force into something made of pressed steel but it works
More brute force, heat & new breaker bar, they eventually succumbed
