Is this right?
Is this right?
The oil slinger was fitted like this when i dismantled the motor. Is it correct?
Not sure about this!
Has everyone gone to the beach? 8) Well i'm going too now. the motor can wait a litle longer 'till I get told! :?
Holly
Post by Holly »
Miles - you posted on a Sunday morning, have patience glasshoppa! ;)
TrevD
Post by TrevD »
this is what is shown in my book , only 3 bolts holding the thrust plate on ( you have one that is not an original bolt . on both the 318 and 360 i have rebuilt one of the bolts has a hole through it to allow oil to run through it and drop onto the oil tab.
now get off the beach you lazy (read lucky) surfer dude and get it back together :lol:
TrevD
Post by TrevD »
ahh i just read your other post , so you have already got this pic , its from the same book.i assume the pic is correct as ive found both the small blocks i dismantled set up like this. if your stuck ill pop down with me board and hit the beach with you :D :D
What oil slinger??? :shock:
Hooray, thanks to all .Kev, I fitted it as you suggested, with only 3 bolts and one for the oil. The pic I posted was wrong, i just wanted you guys to confirm. Problem was, that the 318 which i dismantleed was my guide and the Ch**y mechanic had fitted it wrong.
Matt thanks for the info on front crank oil seal, i'll take due note.
The beach was lovely, the surf is due at the end of the week and I WILL post picsof completed motor. First one of these ive done. I seem to spend every other minute fixing my mates Vespa (cos i know abit about those)
Gratious surf pic enclosed
ps I nust be patient, i must be patient, :banghead:
Matt, hang on a goshdarn minute, one of the bolts has a hole thu it?
Must go back and check that :shock:
No bolts with holes! Surely oil pours thru the one hole that has no bolt owhere the tab onthe oil thrower thingy locates?
Kev, 'what oil slinger?' :shock:
Dont you use one then?
This thread is about camshaft thrust plate. it should be installed with all four bolts. The one in the top left has a hole in it. This lets oil into the camchain area this drips on the chain and oil slinger (the disc infront of the camchain) this "slings" the oil around the camchain area.
TrevD
Post by TrevD »
the bolt at the top , to the left as you look at the engine , should have a 1/8ish ( 3.2mm) hole through it . this allows oil to run onto the little oil tab and so lubricate the chain . Kev you probably gain 0.0000005hp by running the chain dry :D :D that must be your secret to added power :lol:
Thanks men, its getting clearer. it may be pedantic/or stupid but in the diagram of the cam thrust plate it appears as if the little tab on the oil thrower locates into the bottomright hole (of the thrust plate). Thats whats been confusing me throughout (and still is)
I'll get the top left bolt drilled to allow oil thru
I know that this treble pedantic n'all, but Kev (& Terry ) say fit thrust plate with all 4 bolts. How come Trevs diagram (i have the same) shows 3 bolts with the oil tab thingy looking as if it locates in the 4th (bottom right) hole? :?
