68 Charger LL1
68 Charger LL1
I did a few jobs to the car over the summer. I've put the bumble bee stripe on, it took ages to line up properly using water and a little 'Dreft' as a lube.
I've also fitted a auxiliary cooling fan (now the car can sit in traffic all day without worrying that the engine is going to overheat). I bought a 16 inch fan from Ebay for around £30, reversed the polarity and turned the fan blades round to face the opposite direction so it could sit in front of the radiator and blow air rather than suck. Also bought for around £40 (from Ebay again) a billet aluminium thermostatic switch holder which I fitted into the top hose.
My winter job is going to be a brake upgrade for the front, which is in the garage ready to fit.
- DSCI0977.JPG (108 KiB) Viewed 6173 times
- DSCI0976.JPG (135.5 KiB) Viewed 6173 times
- DSC00713_1.jpg (49.44 KiB) Viewed 6173 times
- autofetish
I've copied the links below but not sure if they'll work.Jules wrote:Post a link Nige to the bits you bought if you can ta![]()
Looks great![]()
Jules
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 406wt_1037
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... SA:GB:1123
The thermostat and housing was purchased from LMA Performance (Tel: 08454 304404, email: info@LMAperformance.com)
The fan was bought from JBI Motorsport (Tel: 01279 550037)
If you need more info, let me know
I also bought a universal fan mounting kit, but never used it as I made a mounting bracket. If you or anyone else wants it, let me know and I'll put it in the post, I don't want anything for it.
- DSCI0994.JPG (54 KiB) Viewed 5983 times
