Hi all, does anyone have a tacho wiring diagram?
I have left it in the garage now, but I am sure it has 4 wires.
a black/red/white and a green? it has the shift light built in.
Also the car is a charger, any sugestions on where to fit it? the dash top is pretty good and only has one small crack.
Thanks
Morgan
Autometer tacho install
Hi
I have just been wiring a tacho in my Coronet (to replace the clock that doesn't work).
The problem I have is that when I turn the car off the needle rests at 1000 rpm rather than at zero. But if I then turn to ign then off it resets to zero like it should.
Followed instructions correctly from box (which were the same as above) - any ideas?
Thanks
Martin
Thanks
Martin
