Diff lubrication
Diff lubrication
Hi all,
Got a week off work next week and looking at changing the fluid in my rear diff. Its an 8 3/4 suregrip unit. Been checking the manual which says it never needs to be changed but Im guessing they didnt think there would be many around 44 years on!
Got a couple of queries... What oil would you recommend using and any tips/ hints as to the best way to do this job?? Any do's and dont's???
Cheers and all the best,
Stevr
JohnR
Post by JohnR »
If you take the filler plug out and have a siphon gun you can pull most of it out OR pull the half shafts and undo the diff bolts pull it forward just a bit and most of it will drain out , refill with LIMITED SLIP DIFF GEAR OIL you can get it from Halfords or any good car shop OR put normal gear oil in and trot along to your jeep dealer and get a couple of bottles of the addative and put that in FIRST and top it up with oil OH yes its better if its warm first !!!!!!
John Rutledge
Hi John,
Thanks for the really quick response mate! Ive got a suction gun s will use that to draw the old fluid out as you said, cheers.... Just out of interest, what is the difference between normal and limited slip fluid???
Cheers Steve
LSDs need a special additive in the oil. Otherwise the diff will not "slip" correctly and wear out pretty fast.
John
Post by John »
There is enough room on the rear casing to put a drain plug in. Once that's done it's never a problem to get it all out :thumbright:
Now passed customs.
Now on route.
Now in posession.
Now costing me sh*t loads.
JohnR
Post by JohnR »
JohnS yes there is enough room but its difficult to do when the axle is still on the car
John Rutledge
