904 woes
terryr
904 woes
Post by terryr »
having a bit of trouble with the push button in the valiant ,all oil looks good and levels seem ok ,all works fine except its taking along time to drop into top and you have to drop the revs for it to engage ,but once in its not slipping and drives as normal,wondering if it maybe band adjustment ,and if it is ,is it the one inside or outside the box
DaveBishop
Post by DaveBishop »
Hi Terry its the one outside the box the intermediate band
Cheers Dave
2 x 1969 Dodge Darts
terryr
Post by terryr »
hi dave ,do you rekon its the band causing the delay then
i think you will find your high gear clutch is goosed, try the band in case the timing is out, also be sure your linkage down from the carb is on and set correctly,,,,,,
terryr
Post by terryr »
cheers dunc ,ill climb under it in the week ,would it be worth running around the block with the kickdown disconected to see if it changes anything
terryr wrote:cheers dunc ,ill climb under it in the week ,would it be worth running around the block with the kickdown disconected to see if it changes anything
I wouldn't. It would only make things worse. Just check it is adjusted correctly. Also tighten the band until the adjuster is just snug and back off 2 1/4 turns.
DaveBishop
Ad Duncan says even though the fluid looks OK it seams like there is to much movement in the top and reverse clutches. It a week point on the 904 the intermediate band and the clutches. The kick down linage control's the pressure in the box so if that not adjusted properly you will have problems
904 [320x200].jpg (22.31 KiB) Viewed 642 times
KICKDOWN1 [320x200].jpg (29.49 KiB) Viewed 642 times
