Help needed finding brake parts
AllKiller
Post by AllKiller »
This is my problem
Viper upgrade needs 11.75 Cordoba rotors that are 1" thick so the viper pads need he supplied shims behind the pads
BUT...Ive noticed
Chrysler Imperial etc C body cars use 1.25 thick rotors so no need for Spacers as the same as Viper Rotor thickness. but i think these are 5 x 5 bolt spacing
So Here's the question:- does anyone / who makes 2 piece rotors that i can have C body rotors on a hat to fit the Cordoba / mopar 5 on 4.5 bolt spacing ????
Rotor = 11.75 x 1.25
Just thought it makes things easier if possible with no shimming needed.
:help:
Cordoba 5x4.5 11.75 x 1.00
Imperial 5x5 11.75 x 1.25
I need 5x4.5 11.75 x 1.25.....see :thumbright:
ALL KILLER NO FILLER
AllKiller
Post by AllKiller »
OF COURSE THIS MIGHT BE MORE TROUBLE THAN HAVING THE SPACERS :lol:
But thats hot rodding ;)
Are you sure all C bodies are 5x5? As far as I'm aware, at least some of them are on 5x4.5. Personally I'd fit the spacers, those thicker rotors must weigh a bleedin' ton!
Mick
Post by Mick »
C'mon Steve, you're getting as bad as Paul. Forget the hotrodding, get the spacers in and come out with us on the 13th, or the end of the month. This has got to be the longest brake upgrade in history. LOL
I'm pretty sure my 66 Fury was 4.5.
Mick :thumbright:
Bloody shim the pads for christs sake. :lol:
John
Post by John »
WELL SAID EVERYONE
GET A BLOODY MOVE ON STEVE!! :working: :evil4:
Now passed customs.
Now on route.
Now in posession.
Now costing me sh*t loads.
AllKiller
Post by AllKiller »
OK Ok i get it... ...true about the weight of the rotors Blue :thumbright:
slowly slowy catchy monkey :thumbright:
all aussie rotors after 1970 and before 1978 were hub and hat
but they used the smaller bearing
this catalogue might be usuful for dimensions and that
http://www.dba.com.au/catalogue/download-pdf-catalogue/
ANTON
Post by ANTON »
Split the Calipers and mill them do and then not spacers needed and the Calipers weighs less too.
ANTON wrote:Split the Calipers and mill them do and then not spacers needed and the Calipers weighs less too.
On fire as always Anton :thumbright:
AllKiller
Post by AllKiller »
THANKS ANTON BUT I DONT THINK ILL GO THERE
BLOODY CAPS LOCK
