Hurst Comp Plus shifter rebuild
Great links here for anyone who's not had one of these apart before or has forgotten how it all goes back together ;)
Part 1:
Part 2:
I've now rebuilt my shifter, those links were a big help.
I bought a 2nd shifter- (an ebag bargain shipped via Andy N, ta mate) and I went through both and decided to select the best parts from each to make one goodun.
There were no breakages and both units were working, but some parts had lot of wear and both needed a thorough clean.
Stripping them is pretty easy. Just pop off the stainless dust cover and the pressed steel side cover and wiggle the guts out.
Normally I'd have to leave myself detailed instructions and photos of where and which way round every part fitted. Instead, I just played the youtube links on my laptop as I rebuilt it and had no problem at all :thumbright:
Some thing's weren't as clear as they could have been so I've put some photos here to clarify.
A04 Plastic washer and end piece.jpg (199.52 KiB) Viewed 372 times
A03 Slide spring washer in.jpg (206.89 KiB) Viewed 372 times
A02 Push 1st spring in.jpg (219.23 KiB) Viewed 372 times
A01 Both stripped.jpg (244.35 KiB) Viewed 372 times
More...
Easily the trickiest bit is getting the retaining washer in for the smaller spring.
I stuck the washer just above where it wants to go with grease, then worked the spring down with 2 screwdrivers until there was a gap to slip the washer into place. I had 3 goes at this before success. Be warned!!
A08 Reversy thing drops in.jpg (220.49 KiB) Viewed 365 times
A07 Into battle with 2nd spring.jpg (205.46 KiB) Viewed 365 times
A06 Stick washer with grease.jpg (223.93 KiB) Viewed 365 times
A05 Push 2nd spring thru hole.jpg (234.02 KiB) Viewed 365 times
Next lot.
There's a few differing opinions on whether these assemblies should be greased at all and if so, what with.
I love copaslip so I went for that. I won't be off-roading or doing any desert driving, and at present it seems the trans is coming out of the car about every 50 miles so regular servicing won't be a problem...
A12 Top now slides over.jpg (213.92 KiB) Viewed 352 times
A11 Slide in this way.jpg (201.92 KiB) Viewed 352 times
A10 Assembly ready for case.jpg (206.23 KiB) Viewed 352 times
A09 Wiggle it into the slot.jpg (193.99 KiB) Viewed 352 times
Last lot...
The worst wear on mine was on the slim bolt through the spring sub-assembly, and the main pivot tube
The stop bolts are just screwed in loosely for now- these are adjusted once attached to the trans.
I'll also be fitting my new longer, more angled shift lever- I won't know if it's right until it's all back in the car [-o<
A16 Assembly complete.jpg (225.05 KiB) Viewed 343 times
A15 Lever cover into slot.jpg (208.97 KiB) Viewed 343 times
A14 Press pivot tube home.jpg (204.33 KiB) Viewed 343 times
A13 Line up with podger.jpg (195.45 KiB) Viewed 343 times
It's like having your own on line Haynes manual, well done Paul! :thumbright:
