ansen slot mags
ansen slot mags
Have steelies on the car, also have dog dishes (not on at the mo, prefer the look). Fancy a set of ansen mags. Small bolt pattern. 15 x 7" 4" backspace, 4" PCD. Would these fit all round or would 6" on front be better? What do you think. Thanks, Gerry
Well it's Ansen slot mags all the way for me Gerry, but I think you'll find 7" rims on the front will rub the chassis leg and clip the front of the wheel arch.
Blue will know for sure! ;)
V8 Sam
Post by V8 Sam »
I'm going to be massive hypocritical now.
But those dog dish wheels look the stuff!
Proper mean stance. :thumbright:
but summers coming, want to show a bit of leg!
From all the research i did Ivor is spot on.........6" on the front should give no issues and are about as big as you'd want to go.
7" on the back is fine....dependant on rear end setup i know of some guys in the states that have even managed to get 8's under the rear.......
Personally 6 at the front and 7 at the back should be just fine.
Here's a useful tool for finding out the what the rubber should look like on the rims.......
http://www.kouki.co.uk/utilities/visual ... calculator
AllKiller
Post by AllKiller »
The dog dishes look better I think, and im not a fan of the DD but they look great on yours 8-) :thumbright:
ALL KILLER NO FILLER
thanks guys, i'm all at 6's 'n' 7's :thumbright:
plenty of aussie A bodies running 14 inch 7 inch wide wheel on the front
VF VG dart-a-likes and standard fitment on RT charger
can't think 15 inch would make much odds
standard pacerb steel wheels were 6.5
may be wider track due to disks in the land down under or larger turning circule due to backwards RHD steering (idler and steering box on the chassis facing forwards )
steveo
Post by steveo »
both look good :thumbright: Rallyes look good also :thumbright:
