Wilwood Brake Caliper bore and thread size??
Hi there.
Can anyone advise me of the correct Hose fitting for Wilwood Front calipers?
Thanks in advance.
shovelheadrob
Post by shovelheadrob »
Pete, it will depend on the caliper. If they are from a vehicle specific kit then they should accept the same hose connection as OEM, if they are not vehicle specific then they could still be either 1/8-27 NPT (taper fitting, or if for banjo fitting a straight 7/16 or even metric. See here http://www.wilwood.com/LineKits/LineKits2.aspx it details caliper models.
Is it :
-3 AN male to 3/8 x 24 SAE male straight adaptor with inverted seat.
or:
-3 AN male to 7/16 x 24 SAE male straight adaptor with inverted seat.
shovelheadrob
Are you looking at M/C fittings? The caliper hose fitting won't have a seat.
Great link, Rob; surprised I missed that one...
This is specifically for the caliper to the hard line...
shovelheadrob
Am I missing something, don't you have a flexi from the caliper? Or have you got a hard line from caliper to strut (assuming it's for a race car) then in to a flexi. Either way you'll probably need an npt to -3 fitting adaptor which is the most common.
It is the fitting that goes into the Caliper that attaches to the -AN 3AN Flexi that I am trying to identify.....
Guy
Post by Guy »
Is it these pieces Pete
Not sure, Guy - It may be the shiny ones next to them - or buy the kit...
Thanks for posting...
Guy
Post by Guy »
The one circled are from the flexy to caliper and the shiney ones are from the flexy to hard line allowing the flexy to be clipped to bracket on frame rail
http://www.summitracing.com/int/parts/w ... /overview/
http://www.summitracing.com/int/parts/r ... /overview/
Guy
Post by Guy »
Its as cheap to order the kit mate
Guy wrote:Its as cheap to order the kit mate
I'm thinking that but I do not know what length - the kits vary from 14" to 18"......
Guy
Post by Guy »
I used that kit 18" on my Dart and fits with no issues any shorter it would be tight on extension any longer you would need to loose the excess :thumbright:
:thumbright: :thumbright: :thumbright: :read2:
Guy wrote:I used that kit 18" on my Dart and fits with no issues any shorter it would be tight on extension any longer you would need to loose the excess :thumbright:
Did you hang the callipers to the rear of the spindles?
