Prop Shaft wow's.
Trigger_Andy
Prop Shaft wow's.
Post by Trigger_Andy »
I needed to more the Bee asap and as it not running very well (-5 does not help) I bumped it into drive with around 2000rpm. (I know I know :D )Anyway the Prop has fallen off at the diff. I was racing to catch a flight so Ive not had a chance to look at it.
Hopefully its just the UV joint, right and a simple fix? I get home on Saturday and fly to Houston Sunday so is this something I could pick up easily over there?
Yes. As long as you know which size it is. ;-)
Trigger_Andy
Cheers!:thumbright: :read2:
Dave wrote:Yes. As long as you know which size it is. ;-)
Adrian Worman
Post by Adrian Worman »
Just a thought Andy, unless you fitted the prop and you know different you can't always assume that the spider is the same size all round.
I've used an adaptor joint before that used two different sizes of bearing cup so check the bit left on the prop yoke and the diff yoke;)
Jesus built my hot rod
72 Challenger
65 Barracuda
Six-pack Speedshop
Post by Six-pack Speedshop »
So true, check both parts cause basically there are 3 choices (if not messed / welded with etc.). 7260, 7290 or conversion joint of these.
Andy, the good news is that if its just the UJ it really is a simple job, only a few minutes. You'll be shocked by the very small bolts that retain the UJ to the diff :shock: !
Trigger_Andy
Cheers for the tip Ad! :thumbright:
Ill have a look when I get home the morn. :lol:
MrNorm
Post by MrNorm »
TW71
Post by TW71 »
If this happens on the move ,trans should be inspected, ie no load, high revs not good :shock:
ANTON
Post by ANTON »
If you jake the back of the car up really high you can take the prop off with out draining the trans fluid.
Couple of socket and a vice will help you press the old UJ out of the prop.
www.apdautomotive.co.uk
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
