727 TORQUEFLITE DIFFERENT VERSONS??
nebay
Post by nebay »
HI I'M IN THE PROCESS OF BEEFING UP MY FURY.
IT CAME WITH A 383 AND 727 BOX.
I BOUGHT A IMPERIAL 413 ENGINE AND BOX.
THE BOXES LOOK SIMILAR APART FROM THE REAR OUTPUT SHAFT HOUSING AND THE FURY HAS A LEVER TYPE CHANGER AND THE IMPERIAL HAS A CABLE TYPE CHANGER ON THE SIDE.
IS IT WORTH KEEPING THE IMPERIAL BOX AS SPARES AND APART FROM THE OBVIOUS WHAT ARE THE DIFFERENCES??
ANY INFO WOULD BE APPRECIATED
THANKS
shovelheadrob
Post by shovelheadrob »
Fairly certain that the Imperial box is from a car with push button gear selection. Probably quite hard to find should someone need one. Internally I don't know what will interchange, Duncan, Bish or Blue will probably know. Plenty of stuff available for your box that will make it tough enough for most applications.
ANTON
Post by ANTON »
There are alot of internal differences between these two transmissions.
The pushbutton have different valve body, input shaft, torque converter, housing and the way the prop goes on.
The push button is great for a hot rod but if you want to use a floor shifter then use the more modern 727 as all you need is one cable to oerate it. The push button have two cables to operate it. One for the gear selection and one for the park cable. These push button trannys can be a paint to seal as there are alot more places for them to leak from.
www.apdautomotive.co.uk
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
Yep, although the pushbutton and the later 727 look to be very similar, there arn't many parts that interchange between them.
nebay
Post by nebay »
Thanks for the info guys.
Sounds like sticking with the original box is the way to go...
Anyone after pushbutton box that will be for sale now.
Cheers
Dart Vader
Post by Dart Vader »
Advertise it on rods and sods, bigger market for it
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
ANTON
Post by ANTON »
I might be interested in the push button transmission.
Let em know how much you want for it.
Anton
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
nebay
Post by nebay »
would have thought must be £250 with the converter??
Dart Vader
Only ever worth what someone will pay ! :thumbright:
Anton will give you a fair offer, he's a gent
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
nebay
Post by nebay »
True words.
I didnt even know what it was till not long ago....
Its there if anyone fancies it PM me.
