Disc brakes for my plymouth C body
nebay
Post by nebay »
Now that i'm getting more from my lump under the bonnet the drum brakes all round are starting to feel the pressure of stopping.
i have a 67 Fury vip c body and would like discs on the front at least.
What and where are the best place to get the whole setup in the UK??
Can i pinch them from other cars?
Cheers people
Dart Vader
Post by Dart Vader »
I don't think there is a straight forward off the shelf solution available in the UK, certainly there isn't for other models
Options are generally buy in one kit form the US, but shipping would be quite high.
Or
Use utilise hubs and callipers, possibly a arms from other disc cars such as b bodies etc
This is the route I went with my dart, I used parts from a 73 barracuda disc set up.
Certainly people on here will have done it so there will be people along with better advice
Have you looked on a site like .....www.forcbodiesonly.com.
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Dart Vader
There seems to be quite a lot of topics on the site
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
DO NOT VISIT 'FORCBODIESONLY'....ITS A HARDCORE PROPER CAR PORN SITE!! :lol:
Think this conversion is popular and easier over the pond because the parts are still, around in some junkyards...not so easy here unfortunately.
Have you tried new flexihoses all round?? That can make a difference...
Im doing a very amateur resto of a 66 Fury III....any pics of yours please, specs etc??
Cheers and welcome C body brother :thumbright:
Steve wrote:DO NOT VISIT 'FORCBODIESONLY'....ITS A HARDCORE PROPER CAR PORN SITE!! :
I have just been a little bit sick in my mouth
Envy is a terrible burden Will!! :D
Speak to Jerry, he did the disc conversion on his Fury.
jerry
Post by jerry »
Iv'e got an SSBC brake conversion on my Fury. Think they are about $1100.
I got them some time ago off ebay second hand.Can't comment on how good they are at the mo hopefully at the weekend if all goes to plan.
jerry wrote:Iv'e got an SSBC brake conversion on my Fury. Think they are about $1100.
:thumbright: :thumbright: :read2: :thumbright:
You put that together quick :thumbright:
depends what you want to spend and how DIY you want to be
Anton might be able to help.
bracket for caliper bolted onto the mounts for the drum back plate.
late mopar disk hubs and rotors if you can get bearings to fit...will involve a visit to a bearing place with the bits i'd guess
ideally you'd be looking for a caliper that is lug mounted with 4 pistons
avoid radial mounted because its never easy to make a bracket for that.
light weight modern calipers are expensive and OEM stuff tends to be radial mount these days
Jag XJ calipers 4 pot 3.5 inch lug mount for wide vented disks
90s hilux/4runner/surf/landcruiser calipers 3.5 inch lug mount 4 pot for thin solid disk or wide vented disk
are two i have looked at becasue they at least mount direct to A body and possibly B body disk stubs which have a 3.5 inch mount for the original 1 pot Slider caliper bracket or mopar 4 pot caliper.
the toyota stuff limits you to a smaller rotor than orginal by about 4mm
the jag stuff was for bigger rotors but is heavy.
jag stuff might be the go....its a big car
you need to make sure that the disk rotor swept area is wider then the pads... i.e covers tha pad but the edge of the rotor doesn't hit the pad mounting pins
you don't want any pad overhang because they will not wear in the over hang area and will eventually meet in the middle leaving you with no brakes.
this is a problem with jag calipers and the smller mopar disc rotors the bigger ones should be ok.
jag calipers
AAU2102 AAU2013
Toyota calipers
sumitomo
these
http://www.ebay.co.uk/itm/toyota-hilux- ... 3f321fbbbf
gen ii surf Mk3 hilux
just food for thought
don't buy em yet you need rotor/hub beraings and bracket sorted as well
