Rear diff seal replacement.
Demon James
Post by Demon James »
How involved is this job? I don't have any problems with the diff other than a good ol' fashioned "historic vehicle preservation applicator" or oil; leak.
The leak is enough to leave say 3 or 4 tea spoons a week (please note that these are BS Calibrated tea spoons as used during the reign of the British Empire)
Can I remove the 4 UJ bolts to drop the prop shaft then remove the flange nut on the pinion shaft, remove and then replace the seal and torque it all back up again? Or are we in full disassemble/back lash setting/ potential to mess it up territory?
Or are you all laughing at why am I worrying about a leaky diff "it's an old car" :lol: :lol:
Rear Diff Leak (Medium).jpg (52.57 KiB) Viewed 999 times
Think you can with that diff.
Where is your service manual? :lol:
That nut on the end of the pinion needs to be torqued to 240lbs/ft though. You need a BIG torque wrench.
Demon James
:lol: :lol: I was half reading it on the iPad and half doing a quote for work :lol:
I guess I was after an honest opinion from experience. It seems to presume you'd be doing other work to the diff so it gets a brief mention towards the end and as you say 240 ftlb :thumbright:
That nut will be soooooo tight to get off
Yes I have made the mistake of taking the diff off the car before undoing that nut before.....
Wheels on blocks and a fing big lever.
Dave wrote:Yes I have made the mistake of taking the diff off the car before undoing that nut before.....
:lol: me to
JohnR
Post by JohnR »
MMMMMMMMMMMM good job I have a MASOOOOOOOHIVE big one that goes up to about 20000 ft lbs used to use it to do up the through bolts on the hydraulic breakers for the JCB's they had to be done up to 1500 ft lbs so good luck
John Rutledge
Demon James
:lol: I was planning on hand brake, wheels chocked and strapped to ramp beds then stand underneath with a truck mechanic mates torque wrench [-o<
By chance, he runs his own JCB repair company :thumbright:
Or. You could always swap your leaky Demon for a leaky more door Coronet.
You'd get the better deal as mines at the half shaft so an easy fix ! :D
A decent impact gun should buzz the nut off.....
Snapon high out put gun no chance
Demon James
Mossy68 wrote:Or. You could always swap your leaky Demon for a leaky more door Coronet.
"Leaky" ain't the word dude, I got fluid pouring out the large lock ring on the steering box now!!! Buts that's a whole other thread :runaway!:
Demon James
Blue wrote:A decent impact gun should buzz the nut off.....
That's what I was hoping. I got one that spins the workshop floor if you can hang on for the ride :lol: ;)
The Coronets steering is bone dry ......deal ? :D
