Anyone had their door glass out?
While I've got the door cards off to change the catch, thought I'd look into why the windows rattle so much.
I've fitted new fuzzies both sides of the glass and also the 'windlace' weatherstrip that goes all around the door opening. But I've noticed that at the trailing edge of the door, there's a lot of play between the glass support and the channel it runs up & down in.
Should there be something inside the channel? I think it might be called 'Run Channel weatherstrip' but as far as I can see it would guide the steel glass support, and not the glass itself.
if there's anything missing I'd like to fit it before I put the panel back on.
TIA.
TIA.
- Run channel - door glass 1.jpg (109.75 KiB) Viewed 940 times
- Run channel - door glass 2.jpg (104.09 KiB) Viewed 940 times
Not factory but could you not run some felt down the groove, should help cushion any vibration?
Of course that will depend on how tight the glass sits within the groove!
- autofetish
Looks the same as Triumoh Herald style, which is a metal channel lined with felt stuff, same material as the window fuzzies. The stuff wears away in the end.
You can buy lengths of it for Triumphs and you just have to carefully fix the brackets to the new channels, with rivets or tiny bit of weld whilst keeping the felt wet
Thanks chaps, I did manage to 'find' some low friction nylon (UHMWPE?) channel we use at work. Seems to fit ok with a couple of c'sk M3 screws, but the window is a tad tight to wind up/down. Even with some white lithium spray.
I might see if it'll loosen up / wear in.
see pics.
I the felt would likely work better but I'd need to check the widths as it's not the glass that is guided, it's the metal glass support.
see pics.
- in situ.jpg (102.91 KiB) Viewed 813 times
- guide with channel.JPG (107.11 KiB) Viewed 813 times
- rear glass guide.JPG (125.07 KiB) Viewed 813 times
I have a roll of the proper mohair tape from a glass company.
The original is a shapes rubber part coated in the mohair and held in place by a metal spike at the bottom of the channel
www.apdautomotive.co.uk
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
