Line lock advice needed
Rebel
Post by Rebel »
I've been looking for a line lock, needs to be an electric one though. Done some searching on the interweb and just got confused by the amount of variations.
All the ones I've looked at seem to be made to fit specific cars and the universal ones all look as though they need a fitting kit, but nobody lists a fitting kit for a 68 Charger.
Do I need a fitting kit or is it just a case of plumbing it in to the brake lines?
Does anyone have a link for the one I should be looking for from somewhere?
If it helps, I have a 383 with 727 and by the time the line lock is fitted it'll be manual discs up front and drums out back, I'm thinking of fitting the line lock to hold the front brakes on
TIA
'68 Dodge Charger
‘75 Ford Ranchero
'93 Toyota Hilux Surf
YouTube - Double Zero Garage
Linelocks are "universal" so no specific kit as far as I am concerned.
I much prefer to put then on the front brakes so you can hold them onn, as opposed to fitting on the rear line to hold them off. I think the first option is safer, but each to his own.........
The Summit own brand, or Biondo is fine. All you need to do is fit it into the line for the front brakes from the master cylinder to the distribution block and wire it up. Any additional fittings you might need can be had from Torques Ebay shop.
If you going disk might want to put a bias valve in there also
andyrob
Post by andyrob »
autofetish wrote:If you going disk might want to put a bias valve in there also
I put willwood discs on the front of my sattilite and then after that if you braked hard it would lock the rears up first if you braked hard, so I guess disc brakes need more brake pressure than drums, so in this case id fit the brake bias to the rear drums.
But yes nigel do as suggested above and lock front brakes on rather than lock rear brakes off
life is not a spectator sport
www.andyrobinson.eu
andy robinson
68 572 coronet RT
72 440 chrysler new yorker
69 518 daytona
Rebel
Post by Rebel »
Thanks guys,
I got a bias valve with the disc kit after reading that you need one to prevent the brakes locking up to early, I'll look at summit and biondo to order one.
'68 Dodge Charger
‘75 Ford Ranchero
ANTON
Post by ANTON »
Here is the electric one easy to fit near the master cylinder and run the electrics
http://www.ebay.co.uk/itm/Biondo-Racing ... 4187ac4816
Here is the manual one I have in my car mounted under the dash and it turns the back brakes off so I can control my burn outs and do one while moving.
http://www.ebay.co.uk/itm/APS-Hydraulic ... 5405b366b5
www.apdautomotive.co.uk
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
Rebel
Post by Rebel »
Thanks Anton :thumbright:
'68 Dodge Charger
‘75 Ford Ranchero
lough3969
Post by lough3969 »
I spoke to Anton about these last week.... The argument for having a manual one that cut the rear brakes out and leaves the front working is a winner as far as I can see... Allows for a controlled release... I will be getting Anton to fit mine by the end of the fingers crossed :thumbright:
lough3969
Post by lough3969 »
By the end of the year... :?
Rebel
Post by Rebel »
Decided to go with an electric one, ordered and on its way shortly :thumbright:
'68 Dodge Charger
‘75 Ford Ranchero
I wired my electric one in the rear line with a switch on the dash to switch off the rear brakes. Ran the 1/4 and had forgotten to turn the rear brakes back on....Didn't do it twice!
Which is why you should only ever use a momentry switch with a line lock, once you take your finger off the button the brakes are back to normal.
Agreed, but I think this has already been said.................
lough3969 wrote:I spoke to Anton about these last week.... The argument for having a manual one that cut the rear brakes out and leaves the front working is a winner as far as I can see... Allows for a controlled release... I will be getting Anton to fit mine by the end of the fingers crossed :thumbright:
Why would you want a controlled release? Your rear tyres are spinning anyway.
Manual activation is dangerous. Electric with momentary button on the fronts is the only safe way.
