TORQUE CONVERTER I.D
challenger
can anyone help i,d this converter,i took this out of a car 2 yrs ago believed to be either 3000 or 3500rpm stall got some numbers on it i cant match up, first lot are written in black pen CTF8TCHS then stamped on the ring gear 5h11 and chrg130
- torque converter 3.jpg (86.02 KiB) Viewed 1526 times
- torque converter 2.jpg (54.57 KiB) Viewed 1526 times
- torque converter.jpg (74.62 KiB) Viewed 1526 times
keep it mopar !
- shovelheadrob
challenger
challenger
- Cannonball
the black marker is just from it having been rebuilt at some time at a verter shop,,,,
challenger
It could be possible.challenger wrote:that makes sense dunc, certainly looks like its been apart at some point
I bought two Convertors at the same time.
One threw a Convertor bolt (despite torquing and loctiting) on the 3rd pass.
It actually got loose and it damaged a thread so I sent it to Sussex Autos for a repair. I hoped it just required a helicoil but I guess because it was a blind hole they took it apart.
It must clearly be that one.............
challenger
did pete have both off you then ? it was about 2 yrs ago i fitted the 3800 stall one in his car, pete thought the one in the pics came in very harsh, but i put that down to the shifter cable not being adjusted correctly and as dunc informed me when he had the box to renew the spragg the clutches were burnt which when i double checked the linkage it was off by quite a bit
keep it mopar !
challenger
Both were originally black from the factory.
I am struggling to remember where the other one went so it is entirely possible......the Dart ran a 5500 convertor and I still have it.....I have several 8", 9" convertors "in stock"....even the Bee has a 4000 convertor in it.
This is one occasion when Looser is better
