kick down advise
CRAIG
kick down advise
Post by CRAIG »
Hello, My kick down was working ok before the car sat far about 2 years. I have a locker adjustable cable, I have tried moving the adjuster each way but the kick down still doesn't work. There's resistance on the cable when you pull it by hand so I presume its still attached box end.
What's the procedure on setting the cable up properly, so I know the cables set up right.
1969 Dodge Charger
1972 Chrysler Hardtop
CRAIG
Post by CRAIG »
just found the lockar instructions, will have a look and make sure its adjusted properly
1969 Dodge Charger
CRAIG
Post by CRAIG »
Adjusted the cable as per the lockar instructions.
Throttle revs better as kick down cable was too tight (managed to lay some rubber down on my street)
Thing is its still not kicking down. Would having the lightest secondary spring in the carb affect the kick down at all?
Any ideas?
1969 Dodge Charger
