Line lock fitting
Line lock fitting
Morning all...
Just chewing through some of my winter jobs, one of which is fitting the line lock to my lovely nearly new brake pipes. Nothing like thinking ahead eh ?
So my question is whether anyone has fitted one to the rears rather than the fronts ? So under normal operation you would expect to prime the system, press the button, release the footbrake and the fronts stay locked. Is there any reason you couldnt do this the other way ? So install line lock into rear pipes, press button to isolate BEFORE priming brakes - press the footbrake and you only operate the fronts.
In theory this means you can still control the fronts during burnout - you can let car creep, bring it to a stop etc etc - gives more control than the traditional ON/OFF method.
So thats my question. Anyone used a linelock to stop the rears receiving any pressure at all rather than just to hold pressure in the front ?
Clear as mud ?
The safest way is to set it so the fronts lock on - that's what I do for the track.
Usually people put it in the rear lines :
a) because it may be easier
or
b) so they can easily do burn outs in Tesco's car park.
If you set it up with an electronic momentary (non-locking) switch it is not such a risk, but people who use manual "taps" in the rear line could forget to turn it back on in the heat of the moment and reduce their braking capability....
The intended use is to lock the fronts on but you could use it to lock the rears off if you must, from an equipment point of view it makes no odds. I would also strongly advise the use of a momentary activation switch, no chance of doing something daft that way, nothing worse than finding you only have half your braking circuit operational in an emergency, or at the top end of the track, Kev could tell you a story about that....
Thanks chaps, as always.
Rest assured that like most things it takes me ages but once I do it, I'll do it properly. :)
Ref burnouts and Tesco carpark - yeah, that's more me than 'on the strip' so I think I may well do that. There will be 2 activation switches, one circuit isolator to ensure its completely dead until I want it (with big red light :)) and then an actual 'do it' button. Isolator locking button, 'do it' momentary. Safety first and all that (ironically).
Don't need to make an under bonnet bracket either, given that I am chopping the main line under car to fit the bias controller through floor anyway, I may as well put the line lock in the same run.
Brain in order. ta.
lough3969
Post by lough3969 »
Doo it...
I've been pondering similar set up so would interesting to see this, like the double saftey option.
The Police view Burnouts as a very poor show, not in control of the vehicle, dangerous driving, etc. They nearly shut down the sporting bears one year over that malarkey...
Yup. My dixie horn is apparently racist now too. maybe pod only then. Come on, you'd love to see if i can actually muster enough grunt to break traction :)
Give it to me, I'll spin it up for you!! :evil: :evil: :evil:
68Runner
Post by 68Runner »
I put in a manual lock in my rear line.
Close the line, foot on brake and give it some welly
68 Plymouth Sattelite 383ci
Yep great idea, big burnout, forget to turn the valve back on, no back brakes at the top of the track. That's what happened to Kev.
I just don't like manual taps from a safety standpoint though I know plenty people use them.
I don't think a second switch is really needed, press the momentary switch when driving and nothing happens unless you hold it on and press the brake pedal at the same time.
Dart Vader
Post by Dart Vader »
I'm doing the same, daft question though. I take it the line coming from my master cylinder that is closest to the bulkhead is the rear. and that's where I should put the line lock in if I want to lock the rears out like morgan. # tescoburnout
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Rebel
Post by Rebel »
I always thought that the brake pipe at the front of the master cylinder ( furthest away from bulkhead ) is the rear brake supply.
Might be wrong though, in the middle of making brake pipes and also adding a line loc
'68 Dodge Charger
‘75 Ford Ranchero
'93 Toyota Hilux Surf
YouTube - Double Zero Garage
Yes Rebel, the largest reservoir (nearest the bulkhead) is for the front brakes.
Seems a bit arse about face initially but if you consider that the fronts do most of the work it makes sense.
Rebel
Post by Rebel »
Stu Twin wrote:Yes Rebel, the largest reservoir (nearest the bulkhead) is for the front brakes.
'68 Dodge Charger
‘75 Ford Ranchero
Dart Vader
cheers peeps
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
