replace oil pressure sender - uh ? ...how ?
So after getting a shiny set of three mechanical gauges, getting a pair (big 'n' small ) replacement oil senders and a T-fitting, ordering copper capillary pipe to replace the brittle plastic tube, deciding where the binnacle will sit, I got my tools and headed off today to install said set of gauges.
Thankfully, I started at the sharp end and didn't start feeding stuff through the firewall ...
(just so you know, sender sits at the back of the engine in my Challenger, against the firewall)
God only knows how the sender was put in, but I'm guessing it was while the engine was out, which would explain the spray over from the red paint the block is coated in - after removing air filter to gain access, its made no bloody diff' !
Do I need to remove the dizzy ? the ONLY aspect I have on it is from above, and I'm guessing (again) that the hex nut I need purchase on is below the "bell" - there seems to be a "stepped" ring around it but I'm not sure that it would mate with a socket.
To be fair, considering calling the whole thing off or taking it to someone who can ......
Currently, the idiot light doesn't function and although the levels are good and she doesn't overheat, I don't want to tempt fate.
Am I stupid to think there MUST be another port available to plumb into - if so, I'll just disconnect the old sender and leave as is ?
Any help appreciated, if you're close by and fancy a crack @ it, I'll buy the beer/wine/cider ......
Garp
Garp
- sender1.jpg (70.55 KiB) Viewed 558 times
- Dart Vader
dizzy out will help, mark the position and ensure it goes back in same place
wide socket will go over oil sender
maybe a smidgen of carefully applied heat would help, careful of wires etc
it a fine thread so shouldn't be too hard
more a case of getting enough purchase on it
dv
dv
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Any help appreciated, if you're close by and fancy a crack @ it, I'll buy the beer/wine/cider ......Dart Vader wrote:dizzy out will help, mark the position and ensure it goes back in same place
dv
- Dart Vader
- Dart Vader
oooo I read that again, isn't that odd that when you think you've read one thing and it's actually different.
yes garp that's the pressure.but I think that's what you meant
if you want oil temp then you can get a sandwich plate that goes near the oil filter take off with a temp feed.
dv
dv
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
I can come up to Lyneham Sunday if that suits - be great to meet someone else with a similar car as I have other niggles under the bonnet I'd like explained ...... What you think ?Dart Vader wrote:does it drive? if so why not come up my lair near RAF Lyneham next weekend
garp
