No brake lights.......
Whilst sorting the indicator issue today, I dropped the column slightly to assist in pulling the wires through. Part way through I noticed this on the floor.......now I'm sure I recognise this from the brake peddle contact, but I've got no photos in my archive to show it's position/mount.
The part:
Any ideas or photos chaps...........I'm at a loss on this one, but sure it's the reason for the lack of red lights.
All other lights work as they should. :thumbright:
Rebel
Post by Rebel »
I could be wrong, but it looks like it's meant just clip on somewhere, maybe at the lower part of the steering column?
'68 Dodge Charger
‘75 Ford Ranchero
'93 Toyota Hilux Surf
YouTube - Double Zero Garage
I don't recognise that part at all, doesn't look like any A body brake light switch I've ever seen.
can't see pictures here at work
but the connector for the column indicator switch (6 way or 8 way conector) sometimes has a clip on it so it can be clipped up under the edge of the dash next to the column
Problem solved thanks chaps....... :help:
A night sleep and 10 minutes upside down in the car and all was clear.
When I dropped the column it pulled the earth wire off. Didnt register at the time, but I tucked it up into the loom out the way to undo bolts.
Now have all lights :thumbright:
The part in the pics..........I know I've seen it connected to something but I just can't remember where. The outer black face was the contact.
I'll keep it safe as it must do something. :thumbright:
