Does anyone in the UK hold panels in stock ?
Now I've started grinding back the filler and sealant, used on the floor pans, there are quite a few rotten areas. Ive started to fab a few bits up but it would be easier if I could get a couple rear panels in and just cut it all out
B body Floor pans
Have a go at making them...16g steel sheet, angle grinder with 1mm cutting disc and a bolster chisel...its fun and doesn't take long to do!
- forum 52.jpg (146.05 KiB) Viewed 857 times
- forum 51.jpg (202.78 KiB) Viewed 857 times
- forum 49.jpg (195.82 KiB) Viewed 857 times
- forum 47.jpg (203.47 KiB) Viewed 857 times
- ScottyDave
Thanks Dave. Its not the neatest job ever but it was great fun making the panels and welding them in. Thanks to Blue who very kindly gave me his old MIG welder, I learned the basics of welding and managed to do quite a bit on my old Fury. I did the whole trunk floor, drop offs, outer rear lower quarters and the panels in front of the rear wheel arches. Cost me some time, bit of welding gas and £30 worth of 16g sheet metal.....very satisfying
Thankfully had access to Autofetishs' bead roller for the trunk....it saved me a fortune in panels and was a great way to learn...
If I can do it, believe me, anyone can!
- 20140516_142631_198.jpeg (13.42 KiB) Viewed 804 times
- 20140405_152951_131.jpeg (16.06 KiB) Viewed 804 times
- ScottyDave
