What size fuse for a holley blue fuel pump? Mine died when I gave her the beanz on a dual carriageway ( working as booster to a mech pump on BB chebby) . Got home and found the plastic fuse holder had melted through to the ignition feed though the 20amp fuse fitted was intact?
TBH the pump is only really needed at higher revs though the previous owner said he had it on all the time. I future I'll just switch her on when required. At least it wasn't the fuel pump burn out.
Thanks
Fuse size
- Location: oxford - the dreaming spires where cars in the city are banned
Fuse size
Holley reccomend a 7.5 fuse for it, depends on the gauge of wire used in the circuit though.
If you under fuse it, it'll just blow fuses all day. If you over fuse it the fuse will be fine but the entire length of cable will heat up and cause all sorts of nasties.
'68 Dodge Charger
‘75 Ford Ranchero
'93 Toyota Hilux Surf
YouTube - Double Zero Garage
‘75 Ford Ranchero
