Hi all,
Just need some help, was looking at changing the position of the battery negative cable over the weekend. It's currently bolted to the front most bolt on the headers and it didn't seem the correct place for it.
I undone the bolt and coolant poured out so it went back in rather sharpish!
I've noted that the front has a hex head bolt and the others have studs and nust.
What is the correct position of the cable and should the bolt be a stud as the others with a sealing compound. Car is a 68 charger, with 383.
Cheers
header,batt cable & coolant!
