Oil Pressure......
Oil Pressure......
All,
What is the connection size of the stock oil pressure light on the rear of a SB Mopar?
Id like to hook up my oil pressure gauge and retain the oil pressure light, so thought it may be possible by incorporating a threaded tee?
So looking for the size?
Cheers
Re: Oil Pressure......
i think........
mopar oil fittings 1/8 NPT and 3/8 NPT
the first is about 10 mm diameter so if you undo it and its a tapered pipe fitting of nominally 10 mm you are on the right track
the latter is about 17 mm i don't think my sender is that big
but they used two sizes
NPT national pipe taper and its a US standard
british ones are different thread pitch one thread per inch different just enough to screw it all up :)
Yes 1/8" NPT . I do the same but have my tee at the gauge end to avoid clutter making it even harder getting at the distributor lock bolt. I use -3 hose as I don't trust that flimsy plastic pipe.
Thanks Chaps.
Have you any pictures of your install Blue?
After ive sorted the Trans i'm going to have to bite the bullit and rewire the car.
I want the engine bay to have as little wiring as possible, so having the connection inside tha cabin is a good shout!!
Do you need to draw any oil up the line to get the correct pressure reading, or should it 'auto pirme'?
Cheers!!!! :thumbright:
I'll see what I can do Dave, Gauges are out of the Valiant and I'm in the middle of sorting the Barracuda but I should be able to show you something. No need to prime pressure gauges.
Here you go, Valiant has the small sender to operate a light, Barracuda needs the big canister to operate the gauge in the rallye dash. Both only seem to work correctly if they are upright which is odd as I would imagine they are spring loaded, so bit more difficult to do. The gauge in the dash isn't up to much which is why I wanted a proper gauge, I can't do with stuff not working though so had to go this route.
lough3969
Post by lough3969 »
This is a good idea... :read2:
Pimps in the Front
Hoes in the Back
Chumps in the Trunk
68 Dart Post
Cheers blue.
Have you used a straight 1/8" NPT tee to do that or are the ports different sizes?
All 1/8" NPT.
John
Post by John »
Blue wrote: Sat May 26, 18 7:20 pm Here you go, Valiant has the small sender to operate a light, Barracuda needs the big canister to operate the gauge in the rallye dash. Both only seem to work correctly if they are upright which is odd as I would imagine they are spring loaded, so bit more difficult to do. The gauge in the dash isn't up to much which is why I wanted a proper gauge, I can't do with stuff not working though so had to go this route.
That looks very heavy John ;)
Now passed customs.
Now on route.
Now in posession.
Now costing me sh*t loads.
Don't worry extreme measures have been taken elsewhere to offset it...
