727 Reverse Servo in the UK?
deppmobile
Post by deppmobile »
Anyone know if these are stocked anywhere in the UK? I've hunted but can't find any.
Superior Chrysler 727, 518, 46RE, 46RH Low & Reverse Steel Super Servo
Thanks!
Gerry
Re: 727 Reverse Servo in the UK?
why do you need that ???? a band in good order and adjustment set correctly there is no problem with the stock part, after rebuilding in excess off maybe 500 727 transmissions I have only seen about 3 that have broke,
deppmobile
Funny you should say that, the symptoms I had suggested it might be a problem (taking a while to get into reverse after starting.)
Had a butchers yesterday and it looks fine, and the bore isn't scuffed up or worn.
I'll give you a call to order a new filter and gasket, and maybe a new seal for the servo as it's out :thumbright:
Thanks!
When I was doing Torqueflites a few years ago, shift kits were about the only performance parts anyone stocked, I've seen no evidence that the situation has changed.
DaveBishop
Post by DaveBishop »
as blue said you really only have to use one if the bore is worn it stops the piston cocking over thats all do have to use them
2 x 1969 Dodge Darts
DaveBishop
i ment to say only if the bore is worn
