holley 2bbl 500 can be adapted via an adapter to a Carter BBD manifold
and you should be able to fasion a linkage and kickdown
but get the one that has the big round section to the top i.e that fits a sensible air filter
don't get the muscle car six pack outer carbs, they are designd to work with their partners only
you won't get a new BBD from carter or edelbrock
rebuilt yes from many places but not new.....
only place where they make them new is china the more they cost the more effort the importer has put in to making it work i'd guess
BBDs were used until 91 on jeeps but the late ones have idle stepper motor and electronic fuel cut off..... unless you were taking it to bits for a decent throttle plate or some such then its probably too much hassle.. and again by that stage you may find different idle mix screw thread and taper.
a BBD is a finicky carb to set up
idle mix
accelertaor pump throw
springs
rod sizes fat and thin sections
jets
acclerator pump jet
weight and ball in the accelerator pump which dicates how much exhausts back into the bowl
Bowel vent disk and clip on the acclerator pump flat shaft, fine tunes the fuel level in the bowl under vacuum
the choke needs correct set up
this is done by setting the position of the flap
and the length of the rod that goes to the hot box on the exhuast
then you need to set idle speed and the Fast idle speed cam.
its position is set by the length of the rod from the vaccum kicker to the choke flap lever, length here is critecal to cold running set up
precise setup leads to good cold to warm running with appropriate step down of fast idle to normal idle in 2 steps as the motor warms up
get any of this wrong and the motor bogs when cold stalls when you pull up to a stop light etc
as with all carter carbs. factory set on factory motor Great..... but you need dedication to get it right on a none factory set up
which is why holley sell so many carbs
if you want all torque and no top end and can make your own adapter the 38 38 dgas weber off a V6 ford might work
you'd be bale to get a ford filter for it at least...
it will limit high rpm power but should work good in the 1000 to 4000 rpm range
as per usual imposter carb on a mopar engine will inbolve a load of messing about for throttle linkage and kickdown.
dave
