Another Delivery......Another Question!
Not sure Jerry, I've been in touch with Dr Diff and he's said i could reuse the one on my existing diff or he has new ones for $15 (never stipulated what my current diff is).jerry wrote:thats the one Davehave you got the brass fitting that splits
the rear brakes the goes on the vent? got one here somewhere if you
need it
Not entirely sure if a) the 7.25 has one and b)if so they are interchangable/same size.
Justin has recently done this and said most of the brake lines can be reused as he has on his?
Will find out in spring for sure. If you have got one lying around though buddy, if you'd kindly put it to one side, i'd be greatful!
Chaps, thanks for the help!
Miles/Dave,
The coffers are running low as it is (my original £1.5k budget has been obliterated) so no fancy overdrive stuff for me! 3.55 or 3.73 would be good!
- Dart Vader
you may find that the 7.25 didn't have a breather on it, mine didn't, just a bolt.
As you can see on my axle I've run the 7.25 brake lines just fine, the block lines up with the breather hole in the axle, it really was a straight swap over
- IMG00153-20120601-1402.jpg (169.85 KiB) Viewed 1013 times
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Cheers!jerry wrote:Will do Dave yours if you need it
Looking good Justin..........You bolted it in yet?
Also, have you managed to source or found options for the propshaft?
Cheers Chaps!
I take it the brass brake block is US only part?
- Six-pack Speedshop
By all means Hans let me know what kinda price your talking?Six-pack Speedshop wrote:And otherwise you just order it along with some other parts
