Used to be Blue's Valiant
Carl
Post by Carl »
great work as usual Blue, very inspirational.
*MMA-609*
"Built to be driven!"
Why me??? :banghead:
Blue wrote:
autofetish wrote:I don't like that brake line :shock:
I know it looks like it's in a vulnerable position but it isn't, you'll never know it's there once it's under the carpet.
I remeber you saying cars without carpet look unfinshed
How will you make the carpet look good at the edges without the orginal panels
Your works is epic and it's an epic car
lough3969
Post by lough3969 »
:tumbleweed: have we got to wait till the Nats?
"How will you make the carpet look good at the edges without the orginal panels?"
I dunno yet, I'll work that out in due course..
"Have we got to wait till the Nats?"
Quite possibly, I've done nothing on the car in the last couple of weeks, I'm waiting for parts still and I've had a whole bunch of "life" stuff that needed doing.
Normal service will be resumed shortly....
lough3969
Post by lough3969 »
:atthemovies:
Clutch thrash. Cover had fatigued around all 3 levers, otherwise all good. Clutch looks recent, no makers name I suspect the cover is a rebuilt one. New clutch going in next week. Found a new flywheel in there as well as the pivot and throwout arm, can't believe the amount of new parts I've found on this car.
Good that you found it before you gave it the beans.
What's it like working on a car a stone's throw from your house?? ;) ;)
It's brilliant Pete, I can't tell you how much of a difference it's made.
lough3969
Post by lough3969 »
Good to hear that it wasn't a catastrophic failure 👍🏼 will you be taking the car to any events? Need to see this... I'm lusting after Valiants now. =P~
I've pretty much decided to write this season off fella, moving workshops has put me so far behind I'm looking at it as getting a head start for next year :roll:
You're always welcome to drop in if you're in the area!
lough3969
Post by lough3969 »
May well take you up on that! I'm not that far away. Please keep posting the new work. :thumbright:
Will do, not much new to show at the moment but should be something next week. New clutch in and all back together, next up is finishing off something I started a long time ago...
Started finishing off the rear spring relocation this week. I fitted the boxes for the front mount into the chassis rail a couple of years back when I did the chassis ties and left the rest of the job until now. Calvert sliders replace the rear shackles, as this would have lowered the car an inch, I had to incorporate a spacer into the mounting bracket to keep the ride height the same. Once tacked I'll check to make sure I've allowed enough rearward movement before I finish welding them up.
Nice, never seen or heard of anything like that before :thumbright:
jerry
Post by jerry »
Whats the advantages on this setup Blue verses standard shackles?
