Post
by Anonymous » Thu Jan 13, 05 4:26 pm
My 68 charger loses its power steering under hard acceloration (its fine at all other times) anyone got any idea why.thanks
Posts: 22109 Joined: Sun Apr 18, 04 10:49 pm
Post
by Pete » Thu Jan 13, 05 4:35 pm
Belt slip???
Posts: 24752 Joined: Sun Apr 18, 04 11:23 pm
Post
by Dave-R » Thu Jan 13, 05 4:52 pm
Pete's suggestion is the only one I can think of.
Post
by Anonymous » Thu Jan 13, 05 10:40 pm
thanks for the replys guys that was my first guess as well but its tight and not slipping
Guy
Posts: 5002 Joined: Sun Apr 18, 04 10:20 pm
Post
by Guy » Thu Jan 13, 05 11:04 pm
I had the same problem on my camero after a while I found the problem was that the pully was slipping on the power steering pump shaft. It worked fine when cruising parking etc nail the throttle and then it would stop working.I dont recomend this but cured it by hitting very quickly with the welder but then again it was only a chevy.
Posts: 13955 Joined: Sun Apr 18, 04 11:04 pm
Post
by Kev » Fri Jan 14, 05 12:13 am
Power Steering=PoofDah
The name is Kev, nowadays known as Kevvy or Pommie C***! </center>
Post
by Anonymous » Fri Jan 14, 05 7:25 am
I reckon its belt slip. You won't notice it while the engine is idling but the belt on mine has to be really tight otherwise it squeaks on hard accel.
Post
by Dave-R » Fri Jan 14, 05 8:39 am
Ditto that Bratfink. I used to jam a big lever between the pump and the engine to force the pump out while I tightened the belt.
Of course then you have to start worrying about the bearing....
