What ignition to go for?
- rockinrich01
Sat waiting for my fuel tank to come back from being cleaned out and wondering if i should change my ignition system!!
I've got a 1970 Satellite 318ci, been having a missing problem. It looks like its got a Airtex conversion fitted in the distributor, are these any good and reliable or should i look at changing it all??
What do you all recommend??
Cheers Rich
Cheers Rich
Race With The Devil!!
I have just installed one of these Firecore units that does away with the orange box and ballast. Allows full voltage to the coil and dizzy for better spark. Super simple to fit (as I did it) and the build quality (from what I can see) looks excellent. My first 27 miles shows better running for sure ............. time will tell.
https://www.customwiresets.com/product. ... 308&page=1
Looks as though they are available for small blocks too...
Now passed customs.
Now on route.
Now in posession.
Now costing me sh*t loads.
Now passed customs.
Now on route.
Now in posession.
- autofetish
I`ve left all the existing wirefoolery and have the old dizzy in the boot just in case MilesMilesnMiles wrote:Nice find John, must take a look at the Nats. Should be a tidy installation.
Now passed customs.
Now on route.
Now in posession.
Now passed customs.
Now on route.
Now in posession.
cheap as chips
works
mopar electronic dizzy
Blaster 2
4 pin HEI module
this search for modules on ebay
(AC DELCO,Wells,petronix,car quest,Napa, niehoff,Borg Warner,GM,Mallory,jegs,moroso) (DM 1906,D1906,ACC35361,aCC35367,D2000,21040,ECH TP45, Dr400 ,CBe4,cbe22,10482820,607,555-40600,97857) (module,hei,)
use a coil designed for 12 volts with 0.5 to 0.8 ohm primary
i.e
Blaster 2
or
and these are only £20
http://www.ebay.co.uk/itm/lucas-DLB198- ... 462ed78576
or indeed
an HEI coil like the one used with the module originally
search
HEI coil (DR-35, E41, DR-182, IC22, 342D, GC400,D525)
Obviously if going racing then there are probably better alternatives
but for a reliable street set up....for notta lotta cash
works
Blaster 2
4 pin HEI module
i.e
Blaster 2
or
or indeed
search
- hei_102 (Small).jpg (52.06 KiB) Viewed 2521 times
- aaa hei_pic.gif (19.87 KiB) Viewed 2521 times
I did think about this option Dave but it would have meant keeping the orange box (or alternative) which isnt what I wanted. Plus thye Firecore dizzies are the Bananarama!
Now passed customs.
Now on route.
Now in posession.
Now passed customs.
Now on route.
Now in posession.
sprintgtvgus
I can only say how I have done it, with good results;
Convert from points to Pertronix Igniter II pick-up inside the dizzy.
Fit Pertronix Flame Thrower II Coil.
Remove Ballast Resistor and replace with jumper cable.
I think this is also well proven.
I then keep the ballast resistor and points in the boot if for if I did have some kind of failure.
1966 Belvedere II with 440 and 727
I use petronix a lot and is very simple. Fit straight into a standard dizzy
www.apdautomotive.co.uk
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
